my 98 xj shut off on me this morning going to work. Ive had no problem with this rig, all lights work, ac works,it turns over good just like it is supposed to do it just acts like its not getting fuel. I talked to a mecanic he said maybe a fuel pump or a cam shaft sensor, if it has one the dealer said it might be a switich plate in the distributor. I did check the valve stem in the fuel line by the injectors I guess this is where fuel pressure is checked, i pushed in on the valve stem and gas squirted out while just setting there. need suggestions pleasa.
