old_man
- Loveland, Colorado
I have a high pinion D44 with radius arms on my rig. I have noticed that when flexing, the shock mount is under a severe tortional load. How have you guys mounted your shocks on long arms and such to keep the stress to a minimum?
I am using a standard pin type shock and the bolt/pin is running parallel to the axle and flat in the horizontal plane. At full flex, the rubber is crushed to the point to where it is almost metal to metal. The rubber is crapping out on a regular basis. I've been thinking of mounting the shock pin/bolt at a roughly 45 degree angle in the horizontal plane to try and relieve the binding. Any ideas?
