shock lengths
H8PVMT
Central Maine
my rear shocks for my 3.5" lift are in another state and beat to hell anyways, nothing on q-tec rear shocks say the lift, just the length so can I just measure my lengths on the front ones or are they not the same sizes
thanks
in case I wasn't obvious I need the length to order new ones :roll:
Ideally you would flex your Cherokee and measure for the correct shock lengths. This chart provides the extended and compressed lengths of some common shocks and the lift size they should fit.
Shock Lengths
Brand/Model # Extended Collapsed Travel Position
Napa 37083 (Stock) 21.2 13 8.2 Front
Monroe 32252 (* Stock) 21.25 13 8.1 Front
Monroe 37193 (* 1-3 “ Lift) 24.25 13.37 10.8 Front
Monroe 911524 (* UpCountry) 21.00 13.4 7.6 Front
Doetsch DT3350 ( 3-5” Lift) 26.5 15.5 11.0 Front
ES1000 ES124515 (* 3" Lift) 24.50 14.38 10.0 Front
ES1000 ES121515 (* 0-2" Lift) 21.52 12.72 8.8 Front
ES3000 ES324515 (* 3" Lift) 24.70 14.52 10.2 Front
ES3000 ES321515 (* 0-2" Lift) 20.24 12.45 7.8 Front
ES9000 ES921515 (* 0-2" Lift) 21.75 13.06 8.6 Front
ES9000 ES924515 (* 3" Lift) 24.70 14.52 10.2 Front
Skyjacker SJA-H7016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Skyjacker SJA-H7025 (* 3-5" Lift) 24.75 14.54 10.2 Front
Skyjacker SJA-N8016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Skyjacker SJA-N8025 (* 3-5" Lift) 24.75 14.54 10.2 Front
Skyjacker SJA-M9016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Rancho RS5239 (* 3" Lift) 23.75 14.37 9.38 Front
Rancho RS5128 (* Stock) 20.87 13.00 7.8 Front
Rancho RS99239 (* 3" Lift) 23.75 14.37 9.38 Front
Rancho RS99128 (* Stock) 20.87 13.00 7.8 Front
Rancho RSX17317 (* 3" Lift) 23.75 14.50 9.25 Front
Rancho RSX13036 (* Stock) 20.50 12.87 7.6 Front
Bilstein F4-B46-1798 (Stock+Upcountry) 21.50 13.25 8.25 Front
Bilstein F4-BE5-6241-H8 (4” Lift)……………………………………….………….Front
NAPA 37027 (Stock) 20.0 12.8 7.2 Rear
Monroe 32269 (* Stock) 21.50 13.37 8.1 Rear
Monroe 37194 (* Upcountry) 21.12 13.87 7.2 Rear
Monroe 911525 (* Upcountry) 21.50 13.87 7.2 Rear
Monroe 37029 (1-3” Lift ) 23.00 14.375 8.6 Rear
Superlift SLF-85112 (* 2-4" Lift) 24.00 14.50 10 Rear
Superlift SLF-84140 (* 3-5" Lift) 26.07 15.57 10.5 Rear
Superlift SLF-85080 (* 0-2" Lift) 21.57 13.32 8.25 Rear
ES1000 ES124509 (* 3" Lift) 24.86 14.84 10 Rear
ES1000 ES121515 (* 0-2" Lift) 21.52 12.97 8.5 Rear
ES3000 ES324509 (* 3" Lift) 24.84 14.82 10 Rear
ES3000 ES322509 (* 0-2" Lift) 22.58 13.71 8.8 Rear
ES9000 ES922509 (* 0-2" Lift) 22.58 13.72 8.8 Rear
ES9000 ES924509 (* 3" Lift) 24.84 14.82 10 Rear
Skyjacker SJA-N8058 (* 3-5" Lift) 24.84 14.82 10 Rear
Skyjacker SKA-H7058 (* 3-5" Lift) 24.84 14.82 10 Rear
Doetsch DT-3000 (* 2" Lift) 22.50 13.50 9 Rear
Doetsch DT-3000 (* 4" Lift) 24.50 14.50 10 Rear
Doetsch DT-8000 (* 4" Lift) 24.50 14.50 10 Rear
Rancho RS5194 (* 2-3" Lift) 23.25 14.37 8.8 Rear
Rancho RS5259 (* Stock) 21.50 13.50 8 Rear
Rancho RSX13037 (* 0-2" Lift) 21.12 13.50 7.62 Rear
Bilstien F4-B46-1799 (Stock+UpCountry) 21.50 13.25 8.25 Rear
Bilstein F4-BE5-6686-H6 (4” Lift) …………………………………………….Rear
Note: * These lift heights were included where the shock lengths were found. These were the suggested shocks for that amount of lift. I have no way to ensure these are accurate.
Front Shocks = Bottom Eyelet With Top Stud Mount
Rear Shocks = Bottom/Top Eyelet Mount
Nice.
To add;
OME N35 Front shocks 23.75" open 15.25" closed
OME N36 Rear shocks 22.25" open 13.50" closed
OME N35L front shocks 26.7" open 15.7" closed
OME N36L rear shocks 24.5" open 14.6" closed
The Comforts (C) are the same as the N35/N36
awesome thanks, spent all night searching around and found a few sites that had them by lift height
