While doin a lil wheelin today.....going from 4 lo to 2 hi the shifter hung up between 4 hi and 2 hi. 4x4 is not engaged but Im not sure what the problem is ......Any ideas ????
It is if you have a vacum problem, I had a '87 YJ, wouldn't pull into 4x4, but I put it on the lift and it would go in easy, I had a friend put in the 4x4 posi-lock kit works without fail since, plus get 2 low outa the deal as well. But thats assuming that you have a vacum problem...
