Shes Alive!!!!
Just a thought, have you thought about continuing the wood grain and reproducing the colour over the fenders, it could give a really neat nostalgic look. Oh and I'm envious of your rig
i plan to do that once I get front glass. I need to find the factory color so I can reshoot it and put the wood grain on. Im still brainstorming on how to mold the molding around the glass
I'd recommend having a sticker made to use in place of the stock wood paneling. Try Signpros in OC. They can laser print on vinyl and probably make a good reproduction that will fit better than the old panel.
its already a vinyl stocker. and JCWhitney sells it. but theres aluminum molding at the top and bottom of the "wood" that i need to bend around the fiberglass
gonna need lot's of luck with that project. You'll be lucky if it's aluminum. Most side trim is thin stainless steel, and it doesn't like to bend cleanly. What really sucks is going to be finding long enough peices to go around the flares. Looks like the front door sections should be long enough to fab rear doors out of, but rear fenders are going to be tough. Any idea if they made that trim for a 2-door or a Comanche?
dont do stickers, they will just fade in the sun get some very thin sheets of wood like the kind you use to wrap a round object. Than stain it, seal it, bolt it. its most likely easier said than done
