Here's the problem with a 3" leaf pack. will you have proper shackle angle? not many 3" packs out there. then you run into the shackle, use the stock one? run a 1" or 1 1/2" then your taller than the front. your choice. i am going with a bastard pack at 3 inches. i have bds 3" coils lifetime warranty and high spring rate, re super ride lowers fixed, iron rock offroad adjustable trac bar,double shear bracket, 1 1/2" RE boomerang shackles.bastard leaf packs. and i am going with the doetsch tech 8000 pre runner shocks with built in bump stops.uppers will come later when i can afford them.will also lengthen brake lines.
