Set of "Neon" Bosch 703 injectors
Royal Nonesuch
Pasadena, CA
Hey all,
I have a set of six Bosch 280-155-703 injectors. Pulled them from a pick-n-pull, rebuilt them with all-new Viton orings/filter baskets/pintle caps, and bench tested 'em to make sure none of the ports were clogged. I also checked resistance with a multimeter, and they all were in spec. Ran them in my Jeep for a little while and they worked fine, but ended up going with 746s for my RENIX on cruiser54's advice. These 703s are best run in '91-'98 H.O. engines I believe (99-01 use different harness connectors). They come with the retaining clips.
$65 shipped to you, or you can pick 'em up in the Pasadena area for $60. :cheers:
