MaxxXJ
- Bakersfield CA
Ok so this oilpan is refusing to seal, I bought a rubber type single piece gasket from vatozone, my first attempt I just used the blue RTV between the gasket and pan, i didnt give it much time to cure like it says on the tube and my first drive somewhere It leaked out the front by the timing cover dropped back and down the pan, so I pulled it back down to fix it, I noticed oil between the engine and gasket up front so I figured that was my problem, i got some more blue rtv and put it between the engine and pan and let it cure for an hour before i reinstalled the pan...Nope! Leaking at the same place! So I'm over this BS, I'm about ready to throw in the towel and have it be a mechanics problem.
Is the rubber oilpan gasket a bad design? Should I be using the cork gasket? How can I get a good seal to stop my new pan from leaking?
