slaminsammy
- greenfield,in.
Don't worry about using a carb in cold weather. I have lived in Indiana all my life and a good manual choke is all you need to keep that gas dumper going.
I just noticed this...post #10, third picture from the top.
That's the drivers side bracket but you have it on the passenger side. You got me curious as to what you are cooking up?
you can always port and polish the cast manifolds for better flow, sucks you'll have a screamer hooked up to manifolds though. It would be nice to get a set of block huggers so you can have equal length primarys. Have you looked into building your own headers? it's not that hard, you just alot of patience.
I am in the planing stage of a SBF swap into my 89. I want to keep it simple so I was thinking of this http://www.offroaders.com/tech/Holley-Truck-Avenger-Install.htm and an Edelbrock performer rpm manifold.
In ill you will need a motor from the same year vehicle or newer and they smog check 96 and newer. They will need all receipts of parts and proof of engine year and related smog eqiupment for the year of the motor. this is in the chicagoland area smog. peoria may be easier. TBI on a dart headed smallblock is not a good combo. Tune port would be better but aftermarket would be best. If you can keep the truck registered in fla while you are here it would be easier to drive it in ILL. There is a lot of red tape and hoops to hop thru for late model motor swaps . 95 and older you can do what ever you want no smog.
There is no need to be creative, those mounts will work on 97+ chassis.
AA advertises 84-95...well what about 96? Why did it get omitted? It's the same as 84-95. The new body style came in 97. AA is advertising 84-95 pre OBD II just to cover their a$$.
Reverse the brackets, put them on the frame & save yourself a lot of extra work.
Of course the mounts don't fit, they are in the wrong spot. See below
The mount is supposed to bolt to the inside of the frame "rail", not on top. Now unless you really need the motor that high...drop it; better COG and you won't have to bubble the hood.
I'm not taking offense just trying to figure out the fitment issue. I'll wait for the more detailed pics
I think that if you put the mounts on top, your going to be poking through the hood by about 3". Let's see if we can't get the motor to line up with the mounts the way AA intended and you can make the call which position is best.
