Davinator61
- Kent, Washington
I have a 1991 Laredo with the 4.0L I-6 engine & I need to safely remove the fuel rail without breaking it in order to replace the injectors by the end of this month, but the injectors are absolutely stuck in their bores in the intake manifold. This I found out on two separate occasions when I was removing the intake manifold to do work on the engine. I'm more than a little leery of using pry bars, as they are made of steel & may bend, kink, or even break the fuel rail-in-question. I really don't want to remove the injector retainer clips from the rail until after the rail has been pulled. Any ideas from the rest of yous would be a big help, even though I've got a few ideas myself on how to do it. Thanks in advance.
