Skully
- Dacono, Co.
Dont really need this big combo anymore.
RIDGID 18v power drill & Jigsaw. Comes with charger, (2) batteries.
Used multiple times but still works as any RIGID tools should. A little garage dust and dirt.
Driver/Drill Features
MAX HC HIGH CAPACITY BATTERY for maximum run time
LOCKING CARBIDE CHUCK to hold bits securely
SINGLE SLEEVE METAL CHUCK for easier operation
DIE CAST GEAR HOUSING for added durability
2-SPEED TRANSMISSION for matching power to the task
DIE CAST OVERMOLD CLUTCH RING, 24 POSITION CLUTCH for durability and repeatability
360° AUXILIARY HANDLE allows rotation to comfortable positio
SLIDE STOP PADS for mar resistance on delicate surfaces
TOTAL GRIP OVERMOLD for improved grip and comfort
Specifications
Volts18
Chuck1/2" locking carbide
Speeds0-400 / 0-1600 RPM (no load speeds)
Clutch
24 position
Max Torque
510 in-lbs
Asking $80 OBO PM If interested.
Specifications
Volts18
Clutch
24 position
Max Torque
510 in-lbs
