woodnjeep
- Sterling Heights Michigan
I just finished installing my new HD Trac bar mount.
It fit fine until I installed the new end.
It seems to be about 3/4 of an inch too long.
The new end is a little longer than the TRE that it replaced.
My lift is a RE 3.5 and is about 4 years old at that.
So I'm not sitting quite as high as some of the other XJ's here.
(Although I'm hoping to go as high as 6 one day)
Here's the question.
Can I cut down the Trac Bar down?
How far in is it threaded?
It takes quite a bit just to get the bolt installed through bushing and after measuring it's pushing my axle to the side at least a 1/2 inch or so.
Enough that my steering wheel is now turned to the right when the wheels are straight.
Anyone else have this problem?
