I've got one on mine,but no pix. What do you need to know?
IIRC,the install went something like this:
Install the front mounting bar,but leave it loose.
Get a jack and jack the skid up to the x-member
Center the skid on the x-member from front to back
Make sure you can get the bolt holes in the front mount to line up
Mark the holes on the x-member
Drop the skid,drill out the x-member
Jack the skid back up to the mounting points
Install all four bolts/nuts/washers *loosely*
When you get everything lined up and are happy with it,tighten everything down and you are done!
Since you bought this piece used,I am curious,is there a small section of the upright at the rear of the skid cut off? I had to cut a small section of mine off to make mine work on the Rusty's x-member. Did the original owner use the Rusty's or factory x-member?
Oh,BTW,good luck with it,and do yourself a favor,change the oil now before the install,as it'll be the last time it's gonna be easy
And don't get suckered into buying that Fram Sure Drain POS! I bought one for mine and it took almost 15 minutes for all the oil to drain out
I think next time I'll just try a small funnel through the drain hole and see if that'll work
