I'm dropping in a holly terminator TBI unit on -- currently running a 350 conversion 88 Cherokee, which I stupidly put on a carb rather than EFI.
I currently have a (stainless) fuel line running up the passenger side, in the frame rail, from the tank to the engine compartment It's fairly small diameter, so I plan on using that for the return. I need to run a high pressure line for the EFI, but threading it into the holes where the current line is is damn near impossible.
I really don't want to cut larger holes in the frame to run the fuel line if I don't have to ... thoughts on how to run it? I completely forgot, how are the fuel lines run stock? I'm thinking of maybe running them on top of the rails on the driver side (battery cables are run from the rear to the front outside the frame, so I don't want to run a high pressure fuel line right next to them), and then up into the engine bay near the wheel wells, before the exhaust manifolds or the steering box.
Also debating between solid stainless line vs. stainless steel braided line. Based on what I can tell, the stainless steel braided is just as good for my needs as stainless tube.
anyway, thoughts appreciated
