- Rainy side of Washington
Speedo flaky - doubt it's the same thing. if it's the MJ (I honestly forget which this thread is about now) then the speedo is mechanical drive, if it's the XJ check to see if the wiring harness is hanging on the exhaust. Mine did that, wore through, and the intermittent grounding from the VSS output signal wire vibrating against the exhaust was making the speedo spike randomly to very high speeds.
