CharlesS
- Quezon Province, Philippines
On my 98 XJ I used what the Jeep has installed....
Cut the blue wire going to the condensor fan, extend the wires slightly, purchase a Bosch 30A relay, run 10ga wire from the battery with 25A fuse inline and tie the two ends of the blue wire to lead 87 and the new 12V power source to 87a, install a switch to actuate the relay. The fan will work normally when the A/C is on and when you need the fan.... just flip the switch....
I originally was going to try to actuate the fan using the wiring installed, but discovered that you will throw a code or possibly burn up the ECM by putting a 12V source into it... The ECM operates on signal voltage less than 5V.
Charles
Charles
