Rubicon Express HD track bar bracket and brace ONLY.
Anyone know if that brakcet can be used with a RE standard trackbar (RE1600) to mount it double sheer?
Nope the 1600 has the heim joint at the frame end, it might work with a huge misalignment spacer but most likely not.. The HD bracket uses the small super flex joint..
i use the RE1600 tracbar with the brackets you're trying to sell. it does work.
I ran the RE bracket with a heim jointed track bar. I drilled out the bracket to 5/8" and sourced the proper spacers. It worked perfectly. I am sure it can be done with this setup as well.
Where'd you get the spacers?
you still have those items for sale? looks like jeeperjohn sent me your way and you gots what i needs....
how much for just the bracket? im broke!
Nope, thanks.
A week ago they were sale-pending, I was just curious if (hoping that) the deal might have fallen through...
But yes, I am out of my chapter a bit. You guys still use american dollars out there, doncha?
Robert
