Rubicon 3.5" ?
Silver Bullet
Conecticut
I just purchased a Rubicon 3.5"Superflex lift for my 2000Xj, on top of the standard system I also purchased Pro-Comp 9000 shocks/stabelizer,extended front brake lines and an adjustable trac bar. Have any of you run this lift before, and what have you had to purchase extra, such as degree shims, t-case lowering kits etc.
I am hoping to avoid an SYE, but according to Rubicons instructions it may be required even on the 3.5" lift.
Any tips or advise will be appreciated as I have never installed a lift before and plan to start on my XJ shortly after the Holidays.
Thanks
Silver Bullet
sounds good i went with the 4.5 and i needed 4 deg of shim and a sye, but i have no vibes and it runs great, with the 3.5" you might need the sye some UC's form the facory needed an sye
