Roof rack MPG ?
I dont really notice much difference with my rack either and I carry a spare, hi lift and tools up there all the time.
WebDog i also feel like im getting a lot of drag from my roof rack and my spare tire...have you ever run a full size spare on your roof rack after you put the solid front on yours?
I pulled my 4 Yakama 58" bars with Yakima LandShark kayak holders off and saw no discernible difference in mpg, which surprised the he11 out of me. I did have the fairing on it which might have helped.
i have two thules bars holding a campinglab awning, and I still am up in the high teens and 20's. stock tires 3.55's, etc. 1992 laredo.
I plan on putting a full length "Bajarack Megamule" rack on ASAP, and I'm hoping like the nice yellow one above, to minimize the impact due to a hard, light aluminum fairing.
Cargomaster Safari rack -1 to -2 without spare, -2 to -3 with spare. Wind drag also caused noticable power loss on highway, most prevalently displayed by excessive downshifting/ inability to maintain speed over overpasses. The tubes were half inch-ish and the bottom rungs are pointed to reduce drag.
I have a yakima and have tried taking it off acouple of times never noticed any differance my mpg has takin a dump lately dont know why seems ever since it has gotten so damn cold.
I have never used the wind sheild for the rack because I have lights there will be removing the lights in a couple of days. Will it make any diff if i use the sheild
You have a gigantic wind sail of lights on the roof. If you leave them there and remove the rack expecting mileage to change it's not gonna happen. You'd have to remove both.
I normally get 10.3 mpg. With the roof rack mounted I get 10.2 With a box on the roof rack that was 2 feet high, by 4 feet x 3 feet, the mileage went down to 9.9.
The same thing happens when I put a hitch basket on the rear. Unless you can make your Cherokee bigger, the roof is a good place for light weight bulky items.
But the real news is I went from 13 to 10.3 when I put my Exo Cage on. Half of it is the extra weight, half of it is the ruining the perfect cement block profile!
87 xj 4.0 aw4 31x10.50s stock gears.
Around October I was getting about 20mpg on my drive up the mountains into PA with my square tube rack+5 KC lights+spare and toolbox. Broke down on the way back and just started driving it again this winter after do a rear axle swap and some stuff. Now I'm getting almost 10mpg for some stupid reason without the rack but once I fix the mpg problem I'll be putting the rack back on after some mods to it.
I extended it the full length of the roof and will be trying to make a foldable light bar which when down will have a "spoiler" on top to add some aerodynamics and shoot the air resistance over top the rack and luggage. If I remember I'll get back to this thread on the recordings without the rack and with the lightbar down. Wish me luck
