IslanderXJ said:
I don't see why they wouldn't but... do they work with roller rockers? Most of this is still black magic and pixie dust to me...
OK guys,
Short answer........The "Hyd Roller Cam" will give you more torque and Hp for the same spec., flat tappet cam. it is not affected by the new oils that are causing are HP Flat tappet cams to fail early in life......and Yes Roller Rockers will work the same with a Flat Tappet cam or Roller Cam..
I fill i now a lot about cam shafts,
but in comparison, of some one that nows every thing about cam shafts.....I would probably be in the 10% category on knowledge.
With that said, this is what i think.
The quicker that you can get the valve open, the longer it's at full lift, and then the quicker you can get it close, will give you the most all around power.....wether the cam is designed to run 8,000 rpm or is a low end torque cam.
A Flat Tappet cam (4.0L cams) can only raise the lifter so fast, and close so fast due the the edge of the lifter gouging into the cam if the cam ramp is to steep.
With a ROLLER CAM the Roller Wheel can run up a much steeper ramp then a flat tappet can.
OK now, when a valve starts to open, there is no flow and flow doesn't really get going until about .050" of and inch of lift.
Now a big Flat Tappet cam would have a lot of Duration and "
overlap' (
a short time, when both the int. and ext. valve are open.) the more overlap you have the more top end HP and the higher the torque curve is raise......Meaning,... bottom end Torque is sacrifice for more top en HP
Now if you could wait to open the int. valve, just a few degrees later and then open it up faster then the Flat tappet could................
Let me put it a different way. a good low end torque cam would be in the
250* to 260* of duration cam (this would be a "seat to seat" spec, not a "at .050" spec.)
You would have lots of bottom end torque at the sacrifice of HP at the higher rpm range.
On the other end of the scale, a cam with a lot of duration 280* 290*(and more overlap to boot) of duration would make really good high rpm HP but would lose most of the bottom end torque of the previews cam.....the torque curve would move up the rpm scale too.
OK stay with me here.
Now with a roller cam, you can have 250* of duration cam, that will act like a 290* cam with out sacrificing low end torque....Why?????
When the cam(or valve) starts out to lift the valve, it lift the valve off of its seat late, But pop up to full lift sooner and stays there long, but still closes sooner.(250*.....'time in degree, of the eng, that the valve is open') when you have the valve fully open, is when you will get the most volume of air and fuel in to the syllinder..........the roller 250* cam is at max lift longer (allowing more air in) then the Flat tappet cam. both cams are lifted off of there seats for the same amount of time.... but, the Roller cam gets more air in. and sense the 250* cam has less overlap then the 290 would, there is more bottom end then the 290* cam would have.
Hyd Roller cams have been in modern eng for many a years now...Why?
Because you can make more HP with them with out failing at the emissions station.
These numbers may not be completely accurate but, you get the point!!!
Flash
