roller cam for 4.0
71_nova
PHOENIX
Does anyone make a solid roller cam for lets say 1990 to 1996 4.0.
I wonder if one could be custom made? I would like to put one in a 4.6 stroker.
No, there isn't a roller cam of any kind (hydraulic or solid) available for the Jeep I6. You could have one custom made but it'll probably cost you an arm and a leg. You'd also have to modify the lifter bores in the block to accomodate roller lifters so it ain't gonna be a simple bolt-on affair.
unless your building a race motor I cant see the advantage. (not very usefull in a jeep) with constant adjustment and all.
On a side note theres a guy up here in chatam ON that has a jeep powerd race car I'm not sure what cam he's using but I do know its all custom stuff, crank, intake, rods, valve etc. It makes over 450hp but he rebuilds after every weekend and hes runnig 3 side draft carbs.
my point you can get pretty wild with the stuff out there so why bother?
Agree. A solid lifter cam from Crane Cams or Clifford Performance would be as much as you'd need if you want to build a high-revving stroker producing 320+hp in naturally-aspirated form.
Point taken.
With in the next year, i will be buying a cherokee. I am holding out to find a sub $1000 one. As long as the body is ok, I want to rebuild everything and lift it 6 inches. I live in Arizona, so there are plenty of places to play!!!
hahahahahahaha
sup blake
aint this the best forum? i never go anywhere else for advice
its funny you live a couple of blocks away and i didnt even know you were on this forum, i this sarge is too but i not sure.
you get your motor to the shop yet?
tim
tim
Well, this Sarge is on the forum but I've never been to Canada.
Sarge
the block head and crankwent to the shop on monday and are now done I just need to get some 258 connecting rods. then I can order my stiff andstart building.
