Im trying to find some places that will make a exterior roll cage for the cheapest around in colorado anyone know of anywhere who does that kind of work? thanx
With no cage you are not likely to venture into situations that can be deadly.
With a cage (even poorly/cheaply built) you may have false confidence and venture into a situation where you could roll or worse. It will be about that time you realize the extra dollars on a quality cage are well spent.
But depending on how you value your life, a cheap cage may be what you need.
Personally, I would save up your $$$ and let Grant do a cage for you. He's pretty busy racing right now, but you won't find a nicer cage anywhere. I'm not knocking anybodys cage at all. I've just seen Grant's work. There are damn few people I would trust to do a cage other than myself, and he is one.
