RockToberFest SwapMeet???
Rock2pus
Malaga NJ
Figured I'd get that ball rolling since I havent seen one yet. Whatcha got?
For me, I might have a couple "want to buys"
1. Need a pass side outer knuckle for a 30.
2. front fenders for 97-up (both) color is not important, condition not much either, as I'm going to cut them up a lot. I just ask that the uppermost bend where it bows down from the hood , and the door meetup area, is straight.
To sell:
1. black original hood off my 01..all straight, paint is cracking.
2. pair of 14" Swaway coilovers with dual rate spacers..new in boxes, asking 450.. (they are not remote res.)
3. (2) sets of m14x1.5 thread black lugnuts (one set is hex, the other splined)
both are sets of 32, for late model F250-350, and some late model chevy HD's.
asking 20$ per set, both sets are unused.
4. trailhead auto deflators- new in bag with case 5-20 psi range. 10$
5. 1 pair of RE "Gen 2" front disconnects for 4"-6" lift, lightly used 50$
6. Kilby Onboard air kit (brackets and whatnot to add a York compressor but keep a/c) compressor not included, lots of extra fittings. new, and i'll put up the part # when I remember where the hell I put it. 75$
Rich
cool
if I go Ill have
2 tj rear flairs alittle rash on them but not too bad. 20$
a drop pitman drilled out for a 3/4 bolt. 20$
maybe a few other things. ill update as I remember.
Got a bunch of stuff I've been trying to sell I'd be happy to haul it up next month.
Brand new sticker still on it 35/13.5/15 Toyo MT $150
it's just dirty from rolling around the yard.
Wheels that are 5 on 4.5 $40 a wheel
15x8
15x8
15x8
15x7
A
Also have a full set of TJ fender flares for $50
have a few intake manifolds trade for hard ciders or yuengling if you can get it
YJ t case shifters not sure if it's an upgrade for XJ's?
BNIB $45
each item will cost a good local brew
DS 97+ tail light
gauge cluster out of a 93 has 210k on it
dash out of my 95
hatch from my blue jeep, no plastic interior, had a mouse nest it it last year
ubolts for a 8.25, those will cost a sixer
ubolts for a d44, missing a cople nylock nuts
4.5" tall
i'll take em
btw anyone have any warn lockouts for a 44? need to be for a 19 spline stub...and any spare double cardan d-shafts would be sexy as well..have parts to trade or cash.
I have forsale
waggy 44 knuckles with new studs from parts mike rilled 7/8 with tapered inserts from OTK which i can tig for somebody if they want
high lift jack mounts
97+ dark grey center console
leaf spring plates
e-brake assembly 97+ and also have a 96 assembly
will update list when i get home with more stuff
