andyr354
- North Central KS
Rocker pannels are rusted out and dented up. Did some measuring last night and looking for a few options.
The pinch seam is gone in most places, nothing left. I would be cutting the rocker all the way back to where the floorboard and the interior part of the rocker area meets. Everything is thin and rusty making it a PITA to weld to as well as weak.
Looks like I would need at least 3x6" tube to get the area filled back in well. Tube of that dimension is not easy to find, heavy, and expensive.
Ideas I have come up with:
Run round or square tube of around 1.5 or 1.75 back over to the unirails and use them to support a piece of 2x4x.120 tubing (have a pile of it already) with a piece of 2" angle welded on the backside to fill in the the rocker area.
Just bend up some sheet metal and build new rockers I can weld in and run your typical sliders underneath that.
