Team Willys
www.rocksolidfab.com
- Chattanooga, TN
The engine hoist can really get in the way when trying to fab things up, and I knew I wanted the chassis side engine mounts to bolt on just like factory. I decided I should use as many of the stock holes as possible, so I utilized both the 4 cyl and 6 cyl mount holes/studs to help spread out the load of the more powerful engine. The Hemi weighs 30 lbs LESS than the 4.0 did, so that was a negligible difference, but with almost double the HP compared to the 4.0, I saw it fit to beef the mounts up. I started with CAD (cardboard aided drafting, although I do actually use computer aided drafting for most of the parts I make lol) and made templates on how the plate needed to be cut to fit. Once I had all my templates made, I began tracing them and cutting them out of 3/16 A514 Domex steel, which is 100,000 psi tensile strength (compared to your typical A36 which is only 36,000 psi and is used by most manufacturers). I then bent them and tacked them together to give me a super rigid mounting surface for the mount tabs.
Once the frame plate were all fit up, I finish welded them and bolted them back in. I then needed to have plates for the engine side. I dre some up in AutoCAD and cut them out on the torchmate for a clean design. I bolted them on the engine, then slid it back into the truck and bolted it back up to the transmission for the second time. With everything reinstalled, I moved on to connecting the engine mount plates to the frame mount plates. I utilized a sleeve with poly bushing typical of a Jeep lower control arm. then I just had to make tabs for each side to connect everything.
