Rock krawler flex joints stuck in the arms
90XJay
Trying to install a used rk 3 link gen 2 we bought a few years ago and never even though the joints may not come out but sure enough all 3 flex joints the jam nuts come off but we can't get the joints to spin. We were planning on just putting all new joints in the arms. Last attempt I tried at work was with my bench vice, pb blaster and a breaker bar for leverage trying to spin it but no luck. Think a torch will help or should we just look into making replacement control arms? We already welded the mounts to the frame stiffeners we are installing :/
If the blue wrench fails you might drill a small hole in the arm to get some pb blaster on the inside. Then weld the hole back up when you're done.
