Rk rear 4 link brackets....
I got the balls, do you have the nuts?
:gee:
jeeperjohn said:
Those don't look beefy enough for my tastes. I think a 1/2" grade 10 bolt is the ticket for suspension mounting points.
Uh, those are 1/4" steel brackets and the bolts are 9/16 equivalent grade 8.8 bolts
Must be the picture, made the things look small on my monitor. If they are 9/16 grade 8.8, then they should do the job. I'd like to see what they look like installed. I want to eventually make my own longarm setup kinda like troy's.
