1986xj
- Smithsburg, Maryland
Most all of the OME lift stuff is on now and she looks a bit jacked up in the rear.... I get center of axle to lip of flare measurement of ~20.75 front and just a smidgen over 20.5 in the rear with maybe a little under 100lbs of junk in the back. From what I find this sounds just right and that I netted just a bit over 3" (17.5" front 17" rear is stock???). Is this right and I just had gotten used to looking at it with those worn out no longer arched rear springs?
On a side note since the shocks SW sent were too short I had to drive it shockless..... thats kinda neat
Once I got used to it it weren't so bad just like driving a boat on choppy water :confused1 Now if the sway bars were disconnected that'd be another story..
Mike B.
OME JC1A's, 934's w/10mm packers, RE shackles, JKS LCA's, JKS disco's, Kevin's HD adj. TB conversion, RE SS brakelines, 31x9.50 TSL radials on ZJ Canyon rims.
Mike B.
