rhinolined bottom third
stone-man
I want to re-paint my 95 xj sport but I want the bottom third covered in rhino liner. I was wandering if I could make some sort of design in the rhino liner. Like saw blade or sharks teeth. Should I just tape it, let it dry and try to pull the tape off. Or ist the rhinoliner too hardened by that time? I need some Ideas.
i am sure u could make any design u wanted with it but i definetaly wouldn't let it dry with the tape under it because u won't be able to peel it off, peel it right away and let dry.
There is a tape with an embedded steel wire along the edge that is perfect for what you want to do. It will leave a sharp edge after the covering dries.
HTH
Rev
I'd use mortons bedliner so you can spray it with a paint gun. I did my whole jeep in mortons bedliner and it looks great. My sister did her toyota in it and it looks great as well.
HTH
Rev
This would be the only way to do it properly with Rhino Lining. I sprayed Rhino Lining for a year. The actual Rhino Lining is set up to the touch in 30 seconds after it is applied. Completely hard in under 5 minutes. Oh and Rhino Lining shouldn't be used as a general term in my opinion.
Here is a picture of my jeep with the mortons bedliner paint job.
Here is a picture of my sisters toyota with the mortons bedliner paint job.
