resister in coil base?
catsrevil
Oregon
Heres my problem, My daughters '87 xj would not start I've replaced the tps, cps. It started fine was running great for about 2 minutes shut it off would not start back up, so now I'm testing everything while i was checking the coil (ok) I tested the voltage to it (11.6). Then I checked the ground, lots of resistance but only between the contacts on the base. Thanks for any help.
