Replacement headlights with true Bi Xenon projector retrofitted.
tcm glx
NAXJA Member #1033
Have a pair of Autopal 200mm lenses with MH1 5.0 and GG shrouds. These are true bixenon projectors, installed in a glass lense housing.....best output you can get. Lights are brand new. One autopal has a blemish, when cleaning the bowl getting ready to seal, I used a rag with thinner and scrapped some of the chrome off. Bothers me enough to build a second set. Pics attached! Asking 235 obo shipped. No bulbs or ballast.
Pics of headlight with blemish:
More pics
No blemish
Do you take monopoly money?
What kind of bulbs are needed here? And will these fit in a stock Cherokee without modification? I just drove thru some of the worst weather I've ever seen up here east of portland... And I need better lights ASAP.
Thanks in advance
H1 HIDs are needed. I can supply for an extra 50 bucks.
This will be your saving grace in bad weather.
As for modifying in the xj, should just bolt in
HID's will be bitchin and have a killer cutoff with ZERO blinding of other drivers since these are projector lenses instead of just reflector housings. any H1 halogen bulb should work if you want to be cheap but you would be doing these housings a great disservice.
you have those dust boots dude? the ones i got from you didnt come with em and they get dirty quick. :)
Also noticed those autopal headlight housings wiggle a bit compared to the stock stuff. It's almost as if they are a tad smaller.
GLWS
****** right? 250$ with the bulbs/ballast right? I will send you the cash and address in the morning if you get back to me by then. Thanks!
Note: E-Mail address removed by moderator to minimize chances of Spam harvesting.
Yup
PM sent
