Replacement for factory foglights?
BrianDunning
I'm trying to help my son get his 2001 XJ into decent shape. The factory foglights need to be replaced - one doesn't work and the other has the glass smashed out. Maybe my google-fu is weak but I can't seem to find replacements. Ideally I'd like to find something that's plug & play and will fit the original mounts, and if they're brighter than stock that would be a huge plus. Thanks!
IMO the 1997-2001 XJ fog lights are mostly ornamental. There are lots of better performing choices than stock replacements.
I would recommend upgrading the headlights, LED or H-4 e-code headlamps such as Hella or Bosch.
I put Harbor Freight Implement lights on in the factory fog spot. I made some mounts for them by bending some 1" wide 1/8" thick aluminum flat stock and just drilled holes accordingly. They look factory, and they put out more light than the headlights.
