HenryKrinkle
- WI
Wondering if anyone knows if the large plastic tube from the valve cover to the air intake affects/connects to any of the other smaller tubes in that cluster block. I'd like to route my CCV directly from the valve cover to the intake, bypassing that cluster.
The main problem is the big elbow/grommet is shot and I don't want to spend $50 on a whole new cluster when the rest of them are fine. The grommet/elbow's end was all boogery and falling apart so I whittled it down to fit inside. It does fit, but is a little too short and is pulling the cluster out of it's mount.
Maybe I'll get the elbow for the HO and just run a straight hose over to the intake. Just an idea- will it work ok?
