Ecomike
NAXJA# 2091
- MilkyWay Galaxy
First a little recent history. I have had this beast for 7 years now, and I have put 60,000 miles on it in that time (now at 280,000). I swapped out the AW4 recently, and the TC. I had a small exhaust leak at the flange-donut, got it fixed by a muffler shop last week (new donut), just after finishing the AW4 swap out. He used a torch to loosen the flange (so ???-O2 sensor, and wires???). Then I got it inspected (Texas emissions) and it passed NOx by just 1 PPM, but it passed. Cat is only 18 months, <10,000 miles old. O2 sensor was good before the AW4 swap.
Old AW4 was slipping badly (internal hydraulic leaks, seals too old and worn, not an electrical, TCU problem). The swaped AW4 seems to work fine, but!
Before I did the AW4 swap, I was starting to notice a little pinging at WOT, in 3rd on the freeway. ( I do not have a knock sensor, but the pinging was new, recent problem, last days before the AW4 finally died).
Now, in Park, from start up the engine runs fine, 650-4000 RPM runs fine, but warmed up idle has fallen to about 450 to 500 rpm, for some unknown reason. In drive with AC on the Idle is about 700 rpm!
I test drove it at 0-35 MPH around the neighborhood, and it was fine the first 35 miles. I test drove it first with the TCU disconnected for 2-3 miles, then went to electronic operation in Drive with the TCU connected the last 32 miles, and it seemed fine. The I took it on the freeway today after 35 miles of local low speed testing around the neighborhood, but....
Trying to get up to speed today I got a nasty shudder, like engine was bogging down, but no pinging. The MPH dash, gauge needle was bouncing +/- 2-3 MPH, no long smooth climb like before. Also the TC was always locked up when it bogged down. I know, because I have a custom power switch override, and TC locked indicator lamp, that I installed a few years back that allows me to disable TC lock up, and allows me to see when the TCU sends power to the 3rd solenoid to lock up the TC. So if I see the light come on and the RPM drops about 250 rpm, I know it locked up the TC.
I went ahead and took a 30 mile freeway, each way, test drive tonight, and discovered that if turn off the TC lock up switch and drive in 3rd gear at 45-65 mph (around 2600 to 3000 rpm), the jeep drives fine, no shudder, decent acceleration for an old tired engine, but with the TC locked up at about 35 MPH (2000 rpm or less) it is a little like riding a bucking horse (but a very much milder shudder, than a horse, LOL) at WOT and takes forever to get up to speed, and it does not down shift like it should at WOT, and the MPH needle bounces +/- 2-3 MPH.
Gas mileage since I started these tests (since I finished the AW4 swap), has been about 1/2 of what it use to be.
This may not be a single problem. I need to make list of things to check, and test. Any ideas folks??????
