Qban
- Long Beach, Ca
Before you start tearing into the axle, are you sure the pinion angle is correct? Do you have a SYE? Is the axle pinion 1-2 degrees below the tranfercase yoke? Maybe it's axle wrap causing the noise. Just want to rule that out first.
Yeah I was considering that at first. That axle is lifted 3 inch with an aal, no sye but a 1inch tcase drop. The howling noise is only at a speed between about 50-70, and only when accelerating. I can pretty much feather the gas and make the noise come and go without having to heavily punch the gas so I think that rules out driveshaft and bearings etc...
Anyways, I set it up again on saturday and added 0.006 to the pinion depth, making the total shim 0.034 and the backlash was a comfortable 0.008 to make a nicely centered pattern. I think It's getting closer as the pattern had a good diffused oval look to it near the top of the tooth but not at the root of the tooth.
It still howls, but not as loud as before. I'll try some more and take my time with it until I get fed up and just pay someone else to do it. I just don't want to admit defeat yet, or ever for that matter =) I'm stubborn when it comes to trying to do something correctly.
Thanks for this suggestion!Ratech makes a spacer replacement for the crush sleeve. PN 4114
I got one of those and it worked well for me, especially now that I may have a few more attempts and have to drive on it to know if it's set up properly.
I also found a nice trick for pulling the pinion bearing off. I'm using a bearing separator with the shop press pressing on the threaded side of the pinion, but on the sides of the separator I put some long bolts to pull the two sides of the separator to the underside of the press table and keeps the separator from deflecting upwards and binding on the bearing cage. I'll post a picture next time so hopefully it helps anyone.
