FarmerMatt
- Down on the Farm
I guess the whole point of this is to get away from the military style insert & 2 piece wheel. Mounting, although tedious & time consuming, is doable & not the real issue. Dismounting them is the problem. Let me see if I can explain the process... You can not break down the tires on a machine because you will just be pushing against the insert. First you have to unbolt the 2 wheel halves. Next you have to spread the halves apart & insert some sort of spacers between the halves (I used 2" square tube). Now it's all about the tire hammer & breaking down the bead. If you're good with the hammer you can break down the inner bead decently enough. If you've never held a tire hammer before you will beat up the wheel pretty good & get a damn good workout. The major problem comes with breaking down the outer bead. Since these wheel shells were one piece wheels to start out with they come complete with saftey bead. So now you end up trying to break down the outer bead over a saftey bead with a tire hammer. I'm sorry, but this just aint going to happen. Without the back half of the wheel, putting the tire / wheel combo clamped into the tire machine becomes a tricky proposition. I finally ended up with a hodge podge stack of spacers that would suspend the wheel & insert up off the machine yet still allow the breakdown bar to do it's job. One of my issues is that these 37x17 MTR's are load range "E" & have an insanely thick bead. I'm not sure how other tires would compare, but I doubt I'd have these problems with my "C" range MTR's. I guess the solution would be to not cut tires... Or, not let FishBoy drive your junk... Clear as mud?
Matt
Matt
