Okay, time to update to where I am currently. Last post was about the suspension not looking correct. Well I called Clayton on Friday during my lunch at work and explained what was going on, and he gave me the measurements for what the arms are supposed to be (just the arms themselves, no joints). When I got home I measured them and found the problem. The upper arm is supposed to be about an inch and 3/4 longer than the lowers which would put it at 31.25". Well..... Mine was sittin at 28! Found why my pinion angle looked so jacked up. But by the time I was able to get home and measure them because of the time zone difference Clayton was already closed.
I had two options: 1) wait til Monday to call Clayton and see if they would send me a new arm, and then wait another 4 days or so for it to arrive. Or 2) make the length correct on the arm that I had.
I chose option 2... I've waited long enough to drive this dam thing!
So I found some material that would slip over the Clayton arm and went to town, ended up lengthening it to end up being 31.25" end to end.
http://img.tapatalk.com/d/
14/04/15/emuhevyn.jpg
Here's what is left of the Clayton kit
So now I had all three links, and I just needed to instal the rest of the front suspension. The Clayton directions say adjust the lowers to 36" eye to eye on the joints, so that's where I lined them up. Put everything back together and finally got it sitting on all 4 tires in the garage. With it sitting on all 4s it still looked like the axle was too far back so I measured wheel base and I was only at ~98". Thanks Dustin for helpin me out there! I wouldn't have thought to measure wheel base to see where I was.
I ended up lengthening the lowers out another 2 inches or so, and adjusted the upper to get a decent looking pinion angle. Then it was just double checking everything was torqued down and bleeding brakes and putting shocks on and it was time to rock and roll!
This is the 30's I had on it in the garage to roll it around on.
Out in the driveway for the first time on 33's
Flexin off a 35"
My grandpa seeing it for the first time lifted
That night I went on a little shake down run, this is the only picture I took.
I took my mom and dad on a ride up to wildcat mtn road to watch the sunset last night, they enjoyed the trip
