Thanks for all the comments on the receiver mounted winch. Some punks just ran off with my Olympic bumper and Warn 8000i winch so I'm looking into getting a front receiver mount and being able to take my winch with me. :gonnablow
I also like the flexibility of moving it from front to rear, moving it to another vehicle, and being able to bring it inside your house/garage when it isn't needed. Now I'm just debating on which front receiver bumper to use. I like the Olympic in the 1 I had (Rock bumper), but might get the front receiver one which looks pretty good and is low profile. Do you guys leave the winch in front when you wheel, or is it best to store it and hook it up when needed? I know that can be a pain, but how much more of a pain is it hooked up? I know my Olympic rock bumper was fairly low profile, but it did stick out a bit. I think the removeable winch would do the same and stick out a little more in front, the problem will be getting it as high as possible. Would you lose a lot of strength by running an angle to the multi mount to get it higher? Also what winches can you run? I hear only a few Warn winches are compatible with the multi mount. I'm starting to look at the Warn XD 9000.
1 last question:
Can a removable winch that you attach to your receiver be as strong/stronger than a permanent front mount? I see it tied into 4 or more places etc so I think it would be. I know class 3 tow is 3,500 lbs, what is that all about? I think winching a XJ would be within that weight limit, but can you do more safely for a small while when you need to winch to get yourself unstuck?
Troy
