Rear coil spacer questions
1-tonxj
Colorado
I installed a 3 inch lift on the daily xk front seems reasonable it's an extended clevice so it's not going anywhere but the rest spacer seems like it might be an issue as it eliminates the center of the coil seat that sticks into the coil so to me it seems like the coil is going to slide around since it just sits on this flat pad with no center retainer . I don't off-road my daily but I figure any time the coil gets to end of travel it's going to move . Does anyone here have a 2-3 inch spacer and if so does the coil move around alot . I need to order some bigger tires it looks like a scared cat lifted in stock tires .
