Rear bump stop bolt size and length???
96country
Russellville, AR
I was just wondering if anyone knew what size and approximate length the bolts are? I am planning on adding a spacer under the stop to keep the tires out of the fenders a little better.
Thanks
Or you can purchase an ORGSMfg spring plate that has the outrigger/extension plate welded to it. It will lessen the uptravel as many inches as your springpack is thick.
Or just weld a plate to your own.
