Incredible Hulk
- Burnsville, Minnesota
Ok what the snap? I got home fine, and then today, I look under my drivers rear wheel, and my axle seal is leaking.....AGAIN! I just got done putting in new seals cuz the others got torn when we put in my gears, and now after putting in teh new ones VERY carefully, they are leaking again. I think I am gonna drive it into the river! THis is the 3rd time, and its getting VERY old. I pulled the shaft, and it has torn the seal once again. What on earth would be causing this? It jst has a chunk missing on one side and it lets the diff grease leak out all over my tires. So, I have ATV'd the hole where it got torn, and am gonna just slap a bunch in the inner lip when I put it all together, which more than likely wont last long, so I will need new seals again. However, in the meantime, what on earth would be causing this? I put them in SO carefully last time, that it baffles me how they tore again. It also looks like I got water in my diff, cuz the breather tube spit fluid up into the frame rail so it is dripping out of there, but I just emptied it and the fluid looked fine. How would that happen without water getting in there? Im baffled and agitated, so please help! Its a D44 and I swapped in discs if that matters. Help me gurus!
josh
josh
