S
SeaMonkey
Guest
Finished my install of RE 4 1/2" super flex lift with the heavy duty trackbar and bracket on my 2000 XJ. All was well with no vibs or death wobble untill I started checking the supension on some drainage dips at the store parking lot. Needless to say awful sound coming from driver side front. Ends up that the spring is rubbing or should I say gouging the heavy duty trackbar mount. Not sure what to do to fix it at this point short of taking it all apart again and cutting part of the mount off. Anyone have a better idea? Did I not do something right? The spring seems to be seated correctly and the axle should be centered...it was aligned and looks right on. Here's some pic's even though it hard to see. =:{)
