RE 3 inch ZJ Spring on XJ
Duane
Has anybody used the Rubicon Express 3" ZJ coil on their XJ? If so, how much lift did it net, and how was the ride both on road and off, I talked to RE and they said it was made of the same rod diameter as the 4.5 inch ZJ coil spring that is used on the 5.5 extreme lift kit for the XJ. I know this spring nets about 6.5 inches of lift. I currently have 5" lift in the back and cant use this much lift up front
Thanks
Thanks
I'm putting a pair of ZJ 3" on the front of mine tomorrow it is supposed to net a 4.5" lift on the XJ. I'll let you know.
