I was wondering if someone would be able to provide some direction for my engine issue. I just added a new lift and did some axle work, but I doubt that had anything to do with the new engine problems.
This issue occurs very randomly and maybe once a month, or if I'm running a lot of errands in which I'm turning the Jeep on and off several times within a short period of time.
The problem begins when I start up the Jeep, from a cold start or a warm start, happens in both circumstances, the engine idles extremely roughly. With a little added gas to rev the engine up, everything returns to normal and the engine idles as it should. About a minute or so after the idle goes away, I get the ODB codes for random cylinder misfire... typically cylinders 1,2,3... never the rear 3.
Once I have rev'ed the engine and it returns to normal, it doesn't happen again during that trip. If I shut off the Jeep and turn it back on shortly after, I can expect it to happen again unless the Jeep has been off for the whole night.
So far, I have complete an oil change, new plugs, new coil, and cleaned the throttle body.
Im pretty handy and have the ability to fix the issues on my owe usually, I just need so direction and advice on where to start?
(Jeep XJ 2001, 4.0)
Thanks so much for the help! Truely much appreciated!!!
(Jeep XJ 2001, 4.0)
