Lowrange2
- Abbeville, SC
My jeeps been sitting for a while. I've pulled the headliner out of it so the interior lights are hanging by the wires. The radio won't turn on and the interior lights won't work (I know they ground by their mounting points - they still don't work) I've visually checked the fuses in both boxes. I believe that the switched power to the radio is fine. I Think I'm missing the constant power... Is the constant power for the radio and the interior lights on the same circuit? If so which fuse is it? I don't have a manual...
Edit: THe door locks and power windows don't work either. ... or the power seats
Edit: I just checked all the fuses with a volt meter... It has to be the constant. Also It seems like the battery is draining fairly quickly... I had to jump it off and I let it run for about 10 minutes then cut it off and waited an hour and it was slow to start but made it. Maybe the batt just needs a lil trickle...
