- Oceanside, CA
it's best just to pick up a dial indicator, you can get them for relatively cheap. i think harbor freight sells one for like 19 bucks with a magnetic base. that way you can narrow down the runout and figure out where it's coming from. they're pretty handy for a lot of things.
I actually have one, I'm just not sure where to stick it on the Jeep to get a measurement.
If the dial indicator has a fairly far adjustable reach to it. See if it will stick to the e brake section in the tunnel. Not e brake itself but the little box the e brake rod pokes out of.
If that doesn't work. Use your jack. "assuming you have a good one other than stock" Jack it up so the jack disk sits right next to the output yoke. set it up and slowly spin yoke by hand.
