smalltownbird
- newport news,va
I installed a push button start in my 98 xj with a flip switch. I've been trying to find a write-up on what wires to tap into and how to wire the switch so that I can go keyless. I tried probing the wires I found online for the accessory switch but when flipping the switch I blew the underhood 40amp fuse. Anyone know what I'm missing? Here is a picture:
Right now I have the red power wire under the column wired to the switch then the switch wired to the starter button and the button to the starter wire (I tapped into the red and cut the starter). I need to get the accessories wired to the switch so when I flip the switch it is like turning the key to run. Any ideas?
