xray1971
- Champaign, IL
98 145,000 miles. Had the loose pad knock on driver side. Now new rotors, pads, calipers & hardware. All lubed properly etc. After install had problem with driver side pad catching weird and kind of grinding when apply brakes. The new pads came with shims.
The pad instructions said to shim the trailing edge of the pads only. But the guide rails are worn the most on the leading edge. Any problems with shimming this end of the pads? Or should I forget the shims, take the knuckle to welder, and have metal put on the leading edge guide?
I searched but could not find much on the use of pad shims.
