Project Unicorn
SouthSeaPirate
Florida
Suppose I get to finally start my own build thread after all these years on car forums.
Think Ill start at the beginning; which will hopefully explain the project name :D
So way back I decided I wanted to get back into a Jeep. Something about the 4.0 and good ol' simple, practical, and modular Jeeps.
I also decided I wanted the best; so it was 4.0, 4x4, NBS, and MANUAL!
Turns out that is VERY hard to find!!!
So during a year of searching (yes really, I had to get rides to get about or borrow the better half's Firebird), I gave up and started looking for other cheap SUV's with the same drivetrain; manual, 4x4, etc. Sometimes I would bend and go look at XJ's with autos or 2.5l but would always come home empty handed. Buddy told me to give up as I was "destined for a pink tricycle with rainbow tassels". So I did when I came across a 97 Rodeo; V6, 4x4, manual for only $1k. After much debate with the owner I found out he had just left for college the week prior and would still have to unpack to find the title. The truck was still only a couple hours away at his fathers home, so I could still see it, buy it , get it. After a couple of weeks he determines the title is lost and applies for lost title. Few weeks later his father gets the title and then he mails to the son. So after much time has past we finally get all situated; father now has signed title in hand! I am determined to get this thing, I am committed! Out of just random curiosity, I decide to check Craigslist one more time before heading out. Mind you this is over a year of searching on CL across the state on nearly an everyday basis. And the literal minute before stepping out of the office door to get another vehicle, I finally see my Unicorn!
Two hours later and $1400 poorer;
Cruise control, power mirrors, power windows, keyless entry, full power moonroof, Chrysler 8.25, and coil over plugs ignition. Even harder to find – Zero rust!
Clutch had always been crazy stiff. And on my way back from vacation; boom goes throwout bearing!
Turns out the shaft the TB rides on actually broke in half; -$200, install -$500, and the tires right before the trip -$700.
About two weeks later, I drop a core plug and overheat BADLY before I even notice anything has happened :(
Core plug;
Galled Cyl #2
Lets not forget the core and evap install just before the trip;
So far, she hates me...
The way you have that engine tied down, it looks like a bad animal. :D
I have no doubt Dallas can ensure that you hold the preeminent position.
They are alluding to the fact that there is already another thread with the same title as this one with another Unicorn named cherokee in this very forum LOL.
Also recently there have been many jokes made about the number of unicorns Cal and I have surreptitiously added to peoples vehicles.
Figures lol
Anyway, progress has been made!
Now to get a new alternator, somehow this one is completely locked up and the case itself is broken. Wonder if the ZJ one would work... Ill compare
Little ticked the shop the installed the clutch not only reused the E-torx (after telling them to replace them), but also nearly stripped them out. Hopefully I can find replacements today.
New alt... $130 :mad:
80-2017_03_26_127_9ff88f49d1dfdff5dacf_2_e1e5befe24ff0b58dbefe74e3754a1f0881b008c.jpg
How does this even happen?!
New engine now has all accessories and clutch installed. Basically now ready to install in the engine bay. Wish me luck
They are just regular 3/8 coarse thread. Should be pretty easy to find.
Problem is is length. You'd think 1 3/4" bolts were more rare than gold.
Found two inch grade 5 and enough grade 8 washers to take out 1/4''.
And you can't just cut them down as the threads do not go all the way to the head :/
