EndlessMtnFab
- Paxtonia, PA
If you have read this thread (and looked at all the fancy shmancy pictures) you would have noticed that some of the crossmember bolts are blocked by the crossmember. There will be a skid to cover most of the exposed bolts .... but that still leaves the dilemma of how to access the holes and tighten down the crossmember.
First .... we cut an ugly hole in the tubing. I will spare you the pain of seeing a freehand plasma cut hole. You are welcome. :wave:
Second .... we more carefully use a hole saw since the plasma cut hole was an abortion. The key is to feed it SUPER slowly and don't be surprised if you need a much bigger hole than the tubing actually is. The sloping surface changes the shape of the actual cutout. Then stick some round tubing in it.
Third .... cut the tubing down closer to the correct height and weld it to the crossmember tubing.
Fourth .... grind it down flush. Reweld again ... making the bead wider and regrind smooth if desired.
Another "Rock's Eye" View
And a closer shot of the recessed hole.
